Hi, I loaded new installations of Revit 2024 & 2025 on to a new workstation. I wanted to exclude the PowerShell issue completely so I opened each Revit in turn with a new, metric base, clicked on manage and opened their respective players. I then manually added the location I wanted. closed down the player and Revit. Then opened the Dynamosettings.xml for both the 2.19 & 3.3 Players in notepad and save the DisplayName to the one we wanted. I then opened Revit 2024 and the 2.19 player. This works and points to the location I want.
However, I then opened Revit 2025 and the 3.3 player and just as it did before it took the location and DisplayName from the 2.19 Dynamosettings.xml and overwritten the 3.3 Dynamosettings.xml with the 2.19 settings. These are hand edited changes, with no scripts involved and on fresh machines and Revit installs. In fact the only thing I have edited is the Display name. the rest has been done in the GUI
Dynamosettings.xml from 2.19 (New)
<?xml version="1.0"?>
<PreferenceSettings xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<IsFirstRun>true</IsFirstRun>
<IsTimeStampIncludedInExportFilePath>true</IsTimeStampIncludedInExportFilePath>
<LibraryWidth>304</LibraryWidth>
<Locale>en-US</Locale>
<GraphicScaleUnit>Millimeters</GraphicScaleUnit>
<ConsoleHeight>0</ConsoleHeight>
<ShowPreviewBubbles>true</ShowPreviewBubbles>
<UseHostScaleUnits>true</UseHostScaleUnits>
<ShowCodeBlockLineNumber>true</ShowCodeBlockLineNumber>
<ShowConnector>true</ShowConnector>
<ShowConnectorToolTip>true</ShowConnectorToolTip>
<LibraryZoomScale>100</LibraryZoomScale>
<PythonScriptZoomScale>100</PythonScriptZoomScale>
<ConnectorType>BEZIER</ConnectorType>
<BackgroundPreviews />
<IsBackgroundGridVisible>true</IsBackgroundGridVisible>
<GridScaleFactor>1</GridScaleFactor>
<DefaultScaleFactor>0</DefaultScaleFactor>
<RenderPrecision>128</RenderPrecision>
<ShowEdges>false</ShowEdges>
<ShowDetailedLayout>true</ShowDetailedLayout>
<WindowX>0</WindowX>
<WindowY>0</WindowY>
<WindowW>1024</WindowW>
<WindowH>768</WindowH>
<UseHardwareAcceleration>true</UseHardwareAcceleration>
<NumberFormat>f3</NumberFormat>
<MaxNumRecentFiles>10</MaxNumRecentFiles>
<RecentFiles />
<BackupLocation>C:\Users\*USERNAME*\AppData\Roaming\Dynamo\Dynamo Revit\backup</BackupLocation>
<BackupFiles />
<CustomPackageFolders>
<string>%BuiltInPackages%</string>
<string>C:\Users\*USERNAME*\AppData\Roaming\Dynamo\Dynamo Revit\2.19</string>
<string>C:\ProgramData\Autodesk\RVT 2024\Dynamo\2.19\packages</string>
</CustomPackageFolders>
<DisableTrustWarnings>false</DisableTrustWarnings>
<TrustedLocations>
<string>C:\ProgramData\Autodesk</string>
<string>C:\Program Files\Autodesk</string>
</TrustedLocations>
<PackageDirectoriesToUninstall />
<PythonTemplateFilePath />
<BackupInterval>60000</BackupInterval>
<BackupFilesCount>1</BackupFilesCount>
<PackageDownloadTouAccepted>false</PackageDownloadTouAccepted>
<OpenFileInManualExecutionMode>false</OpenFileInManualExecutionMode>
<ShowTabsAndSpacesInScriptEditor>false</ShowTabsAndSpacesInScriptEditor>
<EnableNodeAutoComplete>true</EnableNodeAutoComplete>
<HideNodesBelowSpecificConfidenceLevel>false</HideNodesBelowSpecificConfidenceLevel>
<MLRecommendationConfidenceLevel>10</MLRecommendationConfidenceLevel>
<MLRecommendationNumberOfResults>10</MLRecommendationNumberOfResults>
<HideAutocompleteMethodOptions>false</HideAutocompleteMethodOptions>
<EnableNotificationCenter>true</EnableNotificationCenter>
<EnablePersistExtensions>false</EnablePersistExtensions>
<EnableStaticSplashScreen>true</EnableStaticSplashScreen>
<DefaultPythonEngine />
<SelectedPackagePathForInstall>C:\Users\*USERNAME*\AppData\Roaming\Dynamo\Dynamo Revit\2.19</SelectedPackagePathForInstall>
<NamespacesToExcludeFromLibrary>
<string>ProtoGeometry.dll:Autodesk.DesignScript.Geometry.TSpline</string>
</NamespacesToExcludeFromLibrary>
<ViewExtensionSettings />
<DisableBuiltinPackages>false</DisableBuiltinPackages>
<DisableCustomPackageLocations>false</DisableCustomPackageLocations>
<DefaultRunType>Automatic</DefaultRunType>
<DefaultNodeAutocompleteSuggestion>MLRecommendation</DefaultNodeAutocompleteSuggestion>
<ShowRunPreview>false</ShowRunPreview>
<GroupStyleItemsList />
<NodeSearchTagSizeLimit>300</NodeSearchTagSizeLimit>
<IronPythonResolveTargetVersion>2.4.0</IronPythonResolveTargetVersion>
<ReadNotificationIds />
<DynamoPlayerFolderGroups>
<DynamoPlayerFolderGroup>
<EntryPoint>dplayer</EntryPoint>
<Folders>
<DynamoPlayerFolder>
<Path>C:\ProgramData\Autodesk\RVT 2024\Dynamo\samples\en-GB\Revit\DynamoPlayer-6</Path>
<DisplayName>Autodesk Samples</DisplayName>
<Id>1</Id>
<IsRemovable>false</IsRemovable>
<Order>1</Order>
<IsValid>true</IsValid>
<IsDefault>true</IsDefault>
</DynamoPlayerFolder>
</Folders>
</DynamoPlayerFolderGroup>
</DynamoPlayerFolderGroups>
</PreferenceSettings>
Dynamosettings.xml from 3.3 (New)
<?xml version="1.0" encoding="utf-8"?>
<PreferenceSettings xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<UseRenderInstancing>true</UseRenderInstancing>
<HomePageSettings />
<RecentFiles />
<TemplateFilePath>C:\ProgramData\Autodesk\RVT 2025\Dynamo\templates\en-US</TemplateFilePath>
<BackupFiles />
<string>C:\Users\*USERNAME*\AppData\Roaming\Dynamo\Dynamo Revit\3.3</string>
<string>C:\ProgramData\Autodesk\RVT 2025\Dynamo\3.3\packages</string>
<TrustedLocations>
</TrustedLocations>
<DefaultEnableLegacyPolyCurveBehavior>true</DefaultEnableLegacyPolyCurveBehavior>
<IsMLAutocompleteTOUApproved>true</IsMLAutocompleteTOUApproved>
<SelectedPackagePathForInstall>C:\Users\*USERNAME*\AppData\Roaming\Dynamo\Dynamo Revit\3.3</SelectedPackagePathForInstall>
<NamespacesToExcludeFromLibrary />
<IronPythonResolveTargetVersion>3.2.0</IronPythonResolveTargetVersion>
<EnableDynamoPlayerRenamedWatchAsOutput>false</EnableDynamoPlayerRenamedWatchAsOutput>
<Folders>
<Id>1</Id>
<Order>1</Order>
</Folders>
Dynamosettings.xml from 2.19 (edited by hand)
<RecentFiles />
<BackupFiles />
<TrustedLocations>
<string>C:\Dynamo\Player\2.19</string>
</TrustedLocations>
<Folders>
<Id>1</Id>
<Order>1</Order>
<Path>C:\Dynamo\Player\2.19</Path>
<DisplayName>Dynamo 2.19</DisplayName>
<Id>1760014833121</Id>
<IsRemovable>true</IsRemovable>
<Order>2</Order>
<IsDefault>false</IsDefault>
</Folders>
Dynamosettings.xml from 3.3 (edited by hand)
<RecentFiles />
<BackupFiles>
<string>C:\Users\*USERNAME*\AppData\Roaming\Dynamo\Dynamo Revit\backup\backup.DYN</string>
</BackupFiles>
<TrustedLocations>
<string>C:\Dynamo\Player\3.3</string>
</TrustedLocations>
<Folders>
<Id>1</Id>
<Order>1</Order>
<Path>C:\Dynamo\Player\3.3</Path>
<DisplayName>Dynamo 3.3</DisplayName>
<Id>1760014395549</Id>
<Order>2</Order>
</Folders>
Dynamosettings.xml from 2.19 (After reopened Revit/Player)
<RecentFiles />
<BackupFiles />
<TrustedLocations>
</TrustedLocations>
<Folders>
<Id>1</Id>
<Order>1</Order>
<Order>2</Order>
</Folders>
Dynamosettings.xml from 3.3 (After reopened Revit/Player)
<RecentFiles />
<BackupFiles />
<TrustedLocations>
</TrustedLocations>
<Folders>
<Id>1</Id>
<Order>1</Order>
<Order>2</Order>
</Folders>
