Hi I am trying to multiply every value with every other value in these three lists. It works, but this way I end up adding for loops if I get more lists. I assume there must be something smarter. Please let me know.
import sys
dataEnteringNode = IN
# Place your code below this line
testx = [1,2,3]
testy = [2,3,4]
testz = [3,4,5]
Result = []
for x in testx:
for y in testy:
for z in testz:
Temp = x * y * z
Result.append(Temp)
OUT = Result
from functools import reduce
from itertools import product
test_list = [testx, testy, testz]
for combi in product(*test_list):
result1 = reduce((lambda x, y: x * y), combi)
Result.append(result1)
The * before a list unpacks it. Technically you could write product(testx, testy, testz). It will just be easier for you to unpack a list, instead of typing it out every time you have a new list. (e.g. product(*test_list)
reduce takes a function and reduces the given list by applying it on each item.
In this case the function is a lambda function that multiplies 2 values
