Multiple tier list loop
Hi guys, sorry if this sounds a little convoluted, I’m trying to use multi-layered list loop,
To turn this:
[[1, 11, 111, 1111], [2, 22, 222, 2222], [3, 33, 333, 3333], [4, 44, 444, 4444], [5, 55, 555, 5555], [6, 66 , 666, 6666]];
into this:
[[1,11,1111], [11,111,1111], [2,22,2222], [22, 222,2222]…[6,66,6666], [66, 666, 6666]]
Basically taking the original 6 list of 4 items, and rearranging them in a specific order into a 12 list of 3 items each
This is the same logic one would use when turning a quad point division into a triangle division, I want to learn how to do it in Python
Here’s my attempt:
import sys
from operator import *
listA = IN[0]
# Place your code below this line
overallList = []
for i in range(5):
	sublist1 = []
	sublist2 = []
	sublist3 = []
	sublist4 = []
	sublist5 = []
	sublist6 = []
	for i2 in range(1):
		sublist1.append(listA[i2][0])
		sublist1.append(listA[i2][1])
		sublist1.append(listA[i2][3])
		sublist2.append(listA[i2][1])
		sublist2.append(listA[i2][2])
		sublist2.append(listA[i2][3])
	for i2 in range(1,2):
		sublist3.append(listA[i2][0])
		sublist3.append(listA[i2][1])
		sublist3.append(listA[i2][3])
		sublist4.append(listA[i2][1])
		sublist4.append(listA[i2][2])
		sublist4.append(listA[i2][3])
	for i2 in range(2,3):
		sublist5.append(listA[i2][0])
		sublist5.append(listA[i2][1])
		sublist5.append(listA[i2][3])
		sublist6.append(listA[i2][1])
		sublist6.append(listA[i2][2])
		sublist6.append(listA[i2][3])
overallList.append(sublist1)
overallList.append(sublist2)
overallList.append(sublist3)
overallList.append(sublist4)
overallList.append(sublist5)
overallList.append(sublist6)
OUT = overallList
There has to be a easier and more elegant solution than what I have.
One for loop and some list slicing should do the trick. Haven’t tested this myself, just typed it out on my phone, but you can give it a go:
OrigList = IN[0]
NewList = []
For lst in OrigList:
    NewList.append(lst[0:2])
    NewList.append(lst[1:3])
OUT = NewList
very close but not quite.
The indices chosen are not sequential, it’s [0,1,3] and [1,2,3]
So it works for the second set, but not the first
So I’m wondering is there some syntax I need to use to pick out specific item from a list 2 layers below?
like List[2][4] works for singular items but not multiple.
Ah. Try swapping in NewList.append([lst[0],lst[1],lst[3]]) then.
YES it works, thank you :clap:
A Design Script alternative :slight_smile:
List.Flatten(List.RemoveItemAtIndex(a<1>,[2,0]<2><1>),1);
