Multiple point creation - sublists
I would like to create two lists of lists of points based on 2 lists of x coordinates and 2 lists of y coordinates.
Let’s call the lists [[Ax], [Bx]] and [[Ay], [By]]. I want to get points [Ax, Ay] and [Bx, By]. The list lengths are [5,4] and [4,3] so I should end up with 32 points. 20 in list A, and 12 in list B. Ideally, these would be broken down into sublists based on Ax and Bx, so 5 lists of 4 points in list A, and 4 lists of 3 points in list B.
I’ve tried playing with the levels at the X and Y inputs of Point.ByCoordinates, but always end up with the wrong number of points.
Do I need python to make this work?
Hi Maase,
Have you tried setting the point-creation node to cross-lacing: xxx in the bottom right (in combination with the list levels)?
Hi Daan,
I have tried that, and it always gives me a multiple of 7 points, (the length of lists Ay + By) -
7 (Ay + By x first item in Ax),
14 (Ay + By x first item in Ax and first item in Bx),
28 (Ay + By x all of list Ax), or
63 (Ay + By x Ax + Bx).
But I still haven’t convinced it to give me Ax x Ay and Bx x By
I have also tried shortest and longest lacing, but maybe it’s a magic combination of lacing + levels?..
Hmm, maybe you could try chopping the first list by lenghts of 1 and using L1 & L2 with list level lacing to longest.
Btw normally I would open Dynamo to take a look myself but I dont have Dynamo available to me this week :frowning:
It seems like a job for list.map, but I don’t know think it’s possible to use list.map on point creation.
This seems suitable for replication guide.
That’s perfect! Thank you. Can you explain how the bracketed numbers work? Is it like levels?
It is called replication guide. You can take a look at the documentation here:
Section 9. Replication and replication guide
DesignScriptGuideV2.1.pdf (343.2 KB)
Section 10. Replication and replication guide
DesignScriptDocumentation.pdf (705.5 KB)
Awesome. It’s like a for loop, which is what I thought I needed. Thank you so much, man.
