it’s my first time programing with Dynamo and i want to import multiple Blocks created in AutoCAD -(image1) into Revit, the coordenates of this blocks are in the notepad (attached file),
i already achieve the import in the x,y,z axis with some errors, but have problems with a node “Element.SetParameterValueByName” to put them in the Revit Model (
Attached image),
after import the points the DWG layer is changed for a Family in Revit, and that is my problem they dont work,because this node anyone have a better solution ? i attached the .dyn file in the link.
Your graph contains rhythm’s version of Element.SetParameterValueByName. I can see on the screenshot, that you already installed rhythm. If you just installed rhythm, just close and reopen the graph, it should find this missing node. I have rhythm version 2020.2.13 installed, and I can’t see your error. If you get this error reopening the graph, try updating the rhythm package.
Hi thanks for your respond the dyn file was a attempt to fix the node with a Rhythm’s node, because the name is very similar, but i dont know how really use it, if you kmow how to use please send me a image, i upload the again the original problem file can you please see again?
