Multiple 3D views from Rooms
I have inherited a dynamo script that will create a 3D view based on the selection of one scope box. What i would like to be able to do is modify this to read all the room values present in the model and create a 3D view for each one. Is this even possible or would you have to do it on an individual basis? I’m sorry I am really struggling today to get my brain to work through this problem, i’m severely jet lagged and sick so i am probably not looking at this script logically!
Any help i would really appreciate as i am being pushed at work to get this to work on a project.
Part 2
Hi @Kirsty_Hogg
Make sure you run the script in 3D view.
thank you i super appreciate your help! @Kulkul
ok i’ve run into a problem, it takes the room names fine but the create 3D cropped view is just pulling null values?
have i missed a node somewhere?
my bad, my dynamo version just needed updating! thank you again you are a lifesaver!!!
@Kirsty_Hogg Make sure your on 3d View before you run the script.
Thank you, great script,
i want to ask how to change the z offset, so I can cut under ceiling.
hi all,
create%203d%20view
i copied the script from Custom node and pasted on Dynamo screen and i gave the inputs and Runned the Script…its showing the error shown in the Screen shot attached.
Can anyone help.
Thanks in Advance.
With Best Regards.
