How do I set a multiline text parameter from dynamo, without using the “String input” node?
Revit does not accept the string “string_line_2 \n string_line_2” from a code block (see pics)
string node:
code block:
string node:
code block:
Can’t you simply use the String.Join node?
nope, same problem?
Think you have to use an actual new line ‘return’ character here. Put it in quotes so it’s a string and you should be fine, though your design script won’t read right.
