Multileader.ByPointsBlock Always Returns Null no Matter the Block Used
Hi all,
I’m trying to create a graph that creates multileaders for storm structures. For some reason, no matter what block I use, the multileader node always returns Null. I’ve tried using AutoCAD’s provided block for these, _TagBox, or any of the other ones, I’ve tried making my own block. Nothing seems to work. My multileader style is set to blocks, and the only other inputs are for location which I’ve tried setting to multiple things. I get no errors, just nulls returned to me. Any help would be appreciated!
Can you make one work? Check the help documentation (right click and select ‘help’) for likely clues.
No, I’ve tried one, even doing the most basic graph I can do with this, it still returns null (again trying any block I have). The help documentation unfortunately doesn’t explain much for this node.
I imagine it’s a block issue, since the ‘block’ input doesn’t need any input, it’ll return null by default. However, it seems weird that I can’t get any blocks to work out of dozens. Has anyone had success with this node? I would love to see how if so.
Figured it out, for anyone coming to this thread in the future:
For some reason there’s issues setting a block in Dynamo. I can set the block in the multileader style and not have anything connected to the block input in the Dynamo graph, then the node works.
Unfortunately gets rid of the dynamo capabilities of setting the block, but atleast this mostly works!
Maybe the block input is not meant for a block but can be used to place it in Modelspace or Paperspace (or inside another block). Other nodes have the same structure.
Oh my gosh, I’ve reread the help section for this node, and you are 100% right. It hadn’t clicked in my head that’s what it meant. Thanks for the info!
