Hi All. So The script below is almost working as it should. Issue is its giving 24 tags per single element. I suspect it might be due to the number of faces, so how do I filter the face to the present view?
its the point values giving the problem
CAN YOU SHARE THIS METHOD.
IF YOU SOLVED THE PROBLEM
I NEED THAT.
