Hello all,
Is there any way to move the edges of one floor at the same altitude of the edges of another floor ?
Thank you in advance!
Hello @SeanP ,
In this case I don’t want to change the floor’s sketch but to modify the altitude of the sub-elements (in order to correspond to the altitude of the other floor)
Hello
you can try with Data-Shapes or Clockwork packages (need to get exactly current vertices to modify them)
an example
script to get vertices (sub-components)
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import*
slab = UnwrapElement(IN[0])
sshape = slab.SlabShapeEditor
verticesDS = [x.Position.ToPoint() for x in sshape.SlabShapeVertices]
OUT = verticesDS
