Move Leader Elbow
Hi Community
I’m trying to move a leader elbow by Setting IndependentTag.LeaderElbow property with a new XYZ. But it throws an exception stating that it cant be moved as long as tag’s leader is straight. Any help will be appreciated!
Straight, elbow position cannot be set.
Not straight, elbow position can be set.
clr.AddReference('RevitAPI')
# def
# start
tag = UnwrapElement(IN[0]) # Grab the Tag
TransactionManager.Instance.EnsureInTransaction(doc) # Start Transaction
new_ElbowLoca = XYZ(tag.LeaderElbow.X, tag.TagHeadPosition.Y, tag.LeaderElbow.Z) # make the line horizontal between TagHeadPosition and Elbow position
tag.LeaderElbow = new_ElbowLoca
TransactionManager.Instance.TransactionTaskDone() # Transaction Commit
OUT = 0
Question.dyn (2.4 KB)
Question.rvt (2.9 MB)
@jacob.small @kennyb6 @Vikram_Subbaiah @Alban_de_Chasteigner Any ideas? :anguished:
https://www.google.com/amp/s/dynamonodes.com/2018/03/01/tag-setleaderelbowposition/amp/
Dear sir i use tagining. Its great dyn.
I have 1 questions its working on one tag one time can i select all tag once then i apply this dyn. And change once.
Because i have big drawing i put all tag once then i use align app for align but many tags arrow shoulder looking above image.
