I have a question. I would like to have control over the X or Y direction from the structural family i want to place.
I can do this with the following code:
But it changes all the values of the same beams that are allready drawn in my project. Is it possible to do this only for the one i want to place with dynamo on a selected edge? So not all the same beams get the same offset?
Thanks!
OR maybe possible tot offset the curve or polycurve in the x/y direction?
you can offset just one beam
but you are now creating a offset for all the beams you selected with the node Family types
you should create a offset value after you created the element
see image
are you als searching for geometry translate node?
parameter you need to set for your element not for all the elements
Thanks oftewel bedankt
going to give it a try tomorrow. I will let know if problem is solved
