As you can see, in my point coordinates, xyz is always 10, but the x coordinate seems to be locked and has not moved, Even if I manually drag and drop, I cannot move in the x direction. I’m curious why? Among them, family type is my customized framework family
when it is a beam it is line based object… can that be the reason? Start/Endpoint
KR
Andreas
We can’t say for certain without know how your family is setup. As @Draxl_Andreas pointed out, this probably isn’t the correct way to place your family if it’s a beam. The family might be reference plane based and therefor locked to a plane. It could be oriented along the wrong axis. Or it may just be constrained. There are a number of possibilities.
