I have a list of families that i want to randomize between a max and min values a single instance parameter.
So far i get the list of families no problem, the parameter name is read perfectly so i just need to find a way to change the value.
I’m assuming i need to assign the random value to the Element.Set.Parameter.ByName value but it needs to be a random value for each instance.
Thanks for your help
It was one of the first discussion that popped when i search )
Unfortunately no, or at lest im too stupid to use it
In this case im looking to randomize a parameter from an instance not a type.
This works fine to set the same value everywhere but i have a feeling that i will need to create another list, with the same number of elements, that contains random values THEN apply that to the parameter.
With the Math.Round i get angle values that i’m looking for.
Then i’m parsing to the individual families. I plug the Math.Round into the value of the Element.SetParameterByName node i get a values in Revit like 515.662 degrees
Revit is hard coded to work in radians. Could you try adding a Math.DegreesToRadians node ?
