Modify railing path curves
Hello Dynamo gurus,
I have read a couple of posts here about retrieving railing curves but none, with solution, about modifying the path, is it possible to do this through dynamo???
Hi @BIMadmin,
Here are some nodes to create railings.
Railing
There is also a method to change the path in the API.
I quickly made a node and it seems to work well.
Hello Alban,
Thank you very muuuuuch again
I had this package out of date, can I ask you how do you manage to have your nodes/definitions up to date.
Hi Francisco,
You’re welcome.
You can drop the custom node in C:\Users\YOURUSERNAME\AppData\Roaming\Dynamo\Dynamo Revit\1.3\packages\Genius Loci\dyf
Or I can update the package tonight if you’re in no hurry.
Thanks Alban,
I am going to try this,
Hopefully will work.
Many Thanks!!!
Hello, I am a beginner in Dynamo, and I need these nodes that you mentioned, how can I get them?
In Dynamo, go to Packages / Find a package and download the Genius Loci package or other packages.
Thank you.
