Dynamo - Railing Curve / Sketch line
Hello!
I am a beginner on Dynamo and i would like to make a script that find the railing in my current plan view and replace it with a detail line. It can be as easy as finding the sketch line and drawing over it.
I am working with Revit 2017 and using dynamo 1.3.1
Sadly i tried to follow some tutorial but it only show how to create a railing with adaptive component.
I tried with a wall family type and it worked perfectly. But it seem like the railing is harder to get the positionning.
Thanks!
There is a node called Railing.GetPath in Zhukoven that could do what you need…
Sadly no, it only work with one railing at a time. I would like to change all the railing to a single Line. Maybe There is an easier way than dynamo?
Springs.Collector.ElementSketch from Spring Nodes could also work but I did not test it on multiple elements
Great i will try it tonight!! Thanks
It’s working! Thanks Yna!
It was simple but useful
Here is the final script
