Modelcompare, script runs unstable, why?
Hello
How can I improve my script? Revit colaps, I want to compare Architecture/Static Model.
For any reason, my script crashes revit at all. Which ways i have to optimize my script?
Geometrieabgleich_V3.dyn (46.0 KB)
I glad about any info or improvement… …would python run more stable?
KR
Andreas
Hi @Draxl_Andreas,
How do you mean Compare exactly?
Also, you could change / compact your script by combining everything in front of the big Code Block by having two groups running through them with all your items.
Also try removing your If-statement and replacing it by List.RemoveIfNot and then put in DesignScript.Geometry.Solid (or something like that) :slight_smile:
thank you a lot for your info i am a single dark Knight in my office :slight_smile:
here a navis extraction
i have 6 floors, in this file. but we have also bigger ones…
i am just testing statik-elements
I tryed to convert:
to this:
OUT = []
for i in str(IN[0]):
    if i == "Solid":
	    OUT.append(i)
if i == 0:
    False
I got some error, is this the correct way?
liste= IN[0]
output = []
for i in liste:
	if i == "Solid":
		output.append(i)
	elif i==0:
		pass
OUT = output
grafik
