Model Line to Room boundary line issue
Hello Dynamiters,
in the workflow I place some revit groups, and later I also place the rooms and the room boundary lines and the room tags. The revit groups contain floors, walls and furniture and also model lines in the location the room boundary lines should be located. I managed to take the information from these model lines in the groups and generate the room boundary lines.
The problem is that the generated boundary lines dont separate the rooms but when I move manually a bit these lines they became “active” and do separte the rooms. I am not sure if the problem is understood but here is an screenshot, where red lines are the generated room boundary lines. Does anybody have any idea how could I sort out the issue?
Thanks in advance
here the def that generate the roomboundary lines
def create_room_boundaries(group, view):
    room_boundaries = []
    origin_List = []
    for member_id in group.GetMemberIds():
        member = group.Document.GetElement(member_id)
        try:
            typ = str(member.CurveElementType)
        except:
            typ = None
        if typ == "ModelCurve":
            if member.LookupParameter("Linienstil") != None:
                if member.LookupParameter("Linienstil").AsValueString() == "<Verdeckt>":
                    origin = member.GeometryCurve.Origin
                    if origin not in origin_List:
                        origin_List.append(member.GeometryCurve.Origin)
                        CurveArray = DB.CurveArray()
                        CurveArray.Append(member.GeometryCurve)
                        sep_line = doc.Create.NewRoomBoundaryLines(view.SketchPlane, CurveArray, view)
                        room_boundaries.append(sep_line)
    return room_boundaries
Hello @igpema
try to change (a little bit) the LocationCurve of ModelCure separation Line
CurveArray = CurveArray()
CurveArray.Append(element.GeometryCurve)
oldCurv = sep_line[0].Location.Curve
newCurv = Line.CreateBound(oldCurv.GetEndPoint(0), oldCurv.GetEndPoint(1) + oldCurv.Direction.Multiply(0.01))
sep_line[0].Location.Curve = newCurv
hello @c.poupin,
great! thanks a lot, somehow you need to move the line a bit to make it works.
here my final def
        try:
        except:
            typ = None
                    newCurv = DB.Line.CreateBound(oldCurv.GetEndPoint(0), oldCurv.GetEndPoint(1) + oldCurv.Direction.Multiply(0.01))
