Model checker dynamo scrypt
I want to develop a Dynamo scrypt that can automatically run the model checker (bim interoperability tools) each time I open a 3D model with Revit. How do I do that ?
Thank you in advance
Hello @yazid.elbouachi and welcome…
you wanna develop a script and have the community to do it for you…without any thing or example ??? please read here…How to get help on the Dynamo forums
Automatically?
Every time.
Well - that will require using the Revit API event handling and an addin.
I’m afraid you are looking at C# .Net application for this.
Yes Aaron…not a task for dynamo
Go check out PyRevit I’d say. It can detect events and if you can write your model checking process in Python or tap into the add-in’s command this way then you could automate it when the model is opened. Pretty sweet.
Hey !
Here is the answer to your question:
It is already implemented in BIT. You just need to build the right xml file, save it in “Automated Runs”, and it will run each you will open Revit.
