Mirror Revit Familys
Hi
I am Dynamo beginner. I’m trying to mirror back allready mirrored families in Revit.
I often need this with mirrored buildings. Unfortunately, I can not find a mirror node. In my example, the families rotate around the axis.I need a similar solution that can mirror and delete the origin family.
GianfrancoRotate Family.dyn (2.8 KB)
Mirrored Familys.rvt (612 KB)
Hello Gianfranco,
Bakery has a node called: Mirror an Element, that be might of use:
Thank you for the answer.
That helped me alot. With the script I can now mirror multiple Elements around the own axis.
The next step is a selection set of the old objects, and then delete after running.
I have tried a lot but no solution.
Have you tried using a delete node in the same graph? For instance Element.Delete from Archi-lab:
I did a little test and with some help from the Clockwork node ‘Passthrough’ this should work:
I thank you. that is the solution
hi, i do the exact same thing and i get no errors but nothing changes in my model space…
nothing gets mirrored, any idea?
fixed , i had to use Levels in ElementList
This node and python didnt work for me with R2018.1, until I changed the following;
From;
return Autodesk.Revit.DB.Plane(normal1, origin1)
(Gave error ‘Cannot create plane as it has no public construct’)
To;
return Autodesk.Revit.DB.Plane.CreateByNormalAndOrigin(normal1, origin1)
Another small improvement.
If you use MirrorElements instead of MirrorElement, then it is possible to choose if a new copy will be placed or the original will just be flipped.
Hmm… nothing is ever so easy…
Managed to get MirrorElements to work, but that method uses an ‘icollection’ of IDs, not a single Id or a list of ids…
This is the working version, IN[2] is true or false to copy the original element or not.
One thing I didnt manage to do is return the new mirrored elements as the output instead of the originals… if someone knows how that can be done it would be useful.
(elems.append before the whole transform?)
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import * #ElementTransformUtils, Plane
clr.AddReference('System')
families = UnwrapElement(IN[0])
planes = IN[1]
copyyn = IN[2] #mirror existing element (false) or make copy (true)
rvt_planes =list()
mirrored = list()
elems = list()
count = 0
def Dyn2RvtPlane(pl1):
	normal1 = pl1.Normal.ToXyz(True)
	origin1 = pl1.Origin.ToXyz(True)
for p in planes:
	rvt_planes.append(Dyn2RvtPlane(p))
for f, rp in zip(families, rvt_planes): #rvt_planes
	try:
#		item.Flip()
		icollection = List[ElementId]()
		icollection.Add(f.Id)
		ElementTransformUtils.MirrorElements(doc, icollection, rp, copyyn)
		elems.append(f)
		count += 1
	except:
		count += 0
		elems.append(null) #To maintain list length if irror fails
OUT = elems, count
For anyone comming across this thread:
Have the elementatransformutils throw everything into a variable. This should give you the IDs of the newly created items.
X=ElementTransformUtils.MirrorElements(doc, icollection, rp, copyyn)
You can also put the f.id within the parenthesis of the constructor like so:
List[ElementId](f.id)
hi there!
Couldn’t get Mirror An Element to work with any family. I wonder am I doing smth wrong or is the node no longer functional? I’ve exactly recreated the setup from the picture in @Gianfranco_Pavan post. Could this setup work with door elements?
Thans in advance!
Managed to find a solution to my own issue. Keyword when mirroring objects is ‘‘flip’’ and not mirror, Clockwork nodes exactly for this task:
“FamilyInstance.FlipFacingOrientation”
“FamilyInstance.FlipHandOrientation”
I am looking for something similar to this. would you be willing post or send and image of the dynamo script?
