How do you call Mesh Toolkit from python to create a mesh ByVerticesAndIndices? I want to accomplish something like:
m = MeshToolkit.Mesh.ByVerticesIndices(vList, iList)
Do I need to addReference and import etc? I can’t find an example that works, but it seems if you already have a mesh, you can say something like aMesh.BooleanUnion(anotherMesh)… but how do you create meshes from scratch in python without visual programming?
Thank you
You’ll first need to import the MeshToolkit namespace. I like to assign it to an alias like mtk. After that calling the method is relatively straight-forward:
clr.AddReference('MeshToolkit')
import Autodesk.Dynamo.MeshToolkit as mtk
verts, indices = IN
OUT = mtk.Mesh.ByVerticesAndIndices(verts, indices)
The only tricky part is that your list of indices has to be of type List< int >.
Thank you. You predicted the tricky part well. So I have a function in the same python script that is returning a list of Points and a list of ints (indices) into the Points list.
fn fixMesh(aMesh):
# vertices is a list of Dynamo Points
# indices is a list of 3 ints each row pointing into the list of vertices
return [vertices, indices]
then:
returnValue = fixMesh(aMesh)
mtk.Mesh.ByVerticesAndIndices(returnValue[0], returnValue[1])
Very simple I thought, but mtk.Mesh.ByVerticesAndIndices is choking on it:
File "<string>", line 100, in <module>
TypeError: Error in IEnumeratorOfTWrapper.Current. Could not cast: System.Int32 in IronPython.Runtime.List
What am I doing wrong or not doing? Thanks again.
If you’re using a Dynamo list of ints directly, the code would just work:
But if you’re generating the list in python, then it will most likely fail if you don’t cast it to the expected c# list type:
import System
verts = IN[0]
indices = (i for i in IN[1]) #generator as an example
meshIndices = List[int](indices)
# would fail when using 'indices' directly
OUT = mtk.Mesh.ByVerticesAndIndices(verts, meshIndices)
Hi again. I followed your example closely and I am now getting the following error:
File "<string>", line 18, in <module>
TypeError: Error in IEnumeratorOfTWrapper.Current. Could not cast: System.Int32 in System.Int64
Here is the python code:
import sys
clr.AddReference('MeshToolkit');
import System
verts = IN[0]
OUT = mtk.Mesh.ByPointsFaceIndices(verts, meshIndices)
And here is the screenshot of the definition:
Thanks for all your help.
Did this ever get solved in REVIT? Because I think it now needs to be solved in C3D25.
