going crazy, and I need the awesome forum help…
I need to Join.List the sub lists of two lists of equal length, but the nodes do not work because there are some Nulls.
In the screen shot, item 0 of both lists needs to be Join.list even if one of them is Null…
The List.Combine has a Join.List in the Comb input.
Resulting Item 0 should be those two Wall elements (Null should just disappear when joined to a list with some elements?), the item 1 should be the joined list of the wall elements in both item 1(s) of the two lists, and so on.
Also tried:
but note that items 1 have 9 walls plus 19 walls, it should be a list on 28 walls, instead of only 19…
Thank you…
Regards
gio
