Probably an easy one for you guys.
I’m trying to join two lists and only keep the values that aren’t null or “”.
Using the A+B drops D. Why? Is there a better way?
Thanks again!
Amigo @Jack buenas, you want Joint List, or Join Strings??
Check this out!!
Thanks! List.SetUnion was the solution. So simple ![]()
Thanks Hamish. Transpose,Concat,Flatten. Thats going to be used a lot.
Hi @Jack ,
I think in your first attempt with the Code Block “a+b” does drop the last item since it is (automatically) set to shortest lacing.
If you use the + node, not a code block, and set it to longest lacing it should work.
