My goal is to create a single flexible pipe run from the centerline of the straight pipe + elbows. I tried to follow T_Pover screenshot however my node keeps returning null. Any type of help would be greatly appreciated.
hello @jonnyXDSSQ and welcome…keep in mind that package is build for ironpythom 2.7 and in never version dont support that without that package installed…i dont say thats the issue but looks like
Thank you for you reply @sovitek , you are most likely correct I did not take into account the versions. Do you know of an updated package / method I could follow?
Thanks for sending over a dyn. SOVI_pipe_system_types and SOVI_flex_pipe_types are custom nodes so Im receiving an error. Can you send over the package or dyf file they are from?
just use element classes-all element of class as you already do
