MEPover - Collect.ModelCategories - Revit 2026/2020
Hi @T_Pover
PS.: Haven’t played with Dynamo for years and usual PowerUsers aren’t available.
I’m using a dynmo script in Revit 2020 which works fine with the package MEPover 2020.6.2.
I’m trying to use the same script in Revit 2026 (Dynamo 3.6.1.2665) but the Collect.ModelCategories node first gives me an error message saying the IronPython2 engin can’t be found.
So I switched it to CPython3 in the node python engin version option but it then gives me this error:
AttributeError : ‘ElementId’ object has no attribute ‘IntegerValue’ [’ File “”, line 24, in \n’]
NODE COMPLET:
clr.AddReference(‘RevitAPI’)
categories = doc.Settings.Categories
model_cat = []
for c in categories:
if c.CategoryType == CategoryType.Model:
if c.SubCategories.Size > 0 or c.CanAddSubcategory:
model_cat.append(Revit.Elements.Category.ById(c.Id.IntegerValue))
continue
OUT = model_cat
What can I do?
Looks like this needs to change according to the Revit API update from 2024 (or was it 2023? 2022?) where element IDs were updated pretty significantly. Try making it just c.Id.Value instead of c.Id.IntegerValue.
Thanks, replaced with c.Id.Value. Launching script and will get back with results
changing script as recommended has repaired the node. Thanks @jacob.small
