Max length,Height & Width of components
Im looking for some help/advice on getting the max length and max width of items in revit.
So what ive done is :
  1. Selected the element,
  2. Created the bounding box of that element
  3. Then get the Height, Length & Width of the bounding box.
This all works fine until i come to sloped elements like a roof panel, then dynamo creates the bounding box on the horizontal plane, giving me incorrect Dimensions
Is there a way to get revit to create the bounding box normal to the plane of the roof panel ?
yes im facing the same issue im trying to reopen this subject hopefully someone will have a solution.
refer to the below image for the script and the revit selection element.
you can see the bounding box in the second image below in dynamo space.
use the nodes given in the script and give it a try
