Maths functions
I’m trying to use this trajectory formula in Dynamo.
y =(h + xtan(x)) - (gx²/2V₀²cos²(x))
You can see I’ve commented out line 21: d = (math.cos^2(angle))
When I try to run it I get the error >> int is not callable<<
which confuses me as it’s not an integer?
also on line 24 when I try to run that line I get the error >>TypeError: unsupported operand type(s) for ^: ‘float’ and ‘int’<<
but the line before does the exact same thing and works fine!
Can anyone shed some light on this please?
@Alien , hi
i use x**2
Thanks… but x^2 should work the same as x**2
Strange, it fixed line g = square of e
However it’s still not working for cosine squared (line 21)
I think the square comes after the cos(), So, cos(x)^2 or cos(x)**2.
It’s the cosine that’s squared, not the angle tho?
Ah, after very much googling I find
:expressionless: :scream:
So… going with this which seems to be OK… we shall see :smiley:
Also apparently; x^2 is a bitwise XOR… um…
OK… have to admit, something doesn’t look ‘quite’ right here.
Hi @Alien ,
Try something like this:
y = ystart + x * Math.Tan(angle) - gravity * (Math.Pow(x,2)) / (2 * (Math.Pow(velocity,2) * (Math.Pow(Math.Cos(angle),2))));
Thanks :smiley:
I forgot to say I did fix it:
I’d like to add a bounce - either on the floor or against a wall…
But … it’s scary :laughing:
Just to clarify, it’s the same thing. Mathematically, sin²(x) = sin(x)². However, sin(x)² is not the same as sin(x²). Hopefully that makes things a little clearer.
Thanks! Having to read up on all of this is time consuming!
I wish I’d stayed in school :crazy_face:
I had to double check myself. It’s been a while lol.
And just to reiterate… This forum is awesome and I really, really, really (yes, that much) appreciate all the help :slight_smile:
