I’m trying to use the code from here to get the ScheduleField list from my material takeoff schedule. Since the standard “ScheduleView.Fields” node was returning an empty list.
For a MaterialTakeoff schedule, the line:
ids = definition.GetFieldOrder()
returns an empty list.
I’ve been searching around, but i can’t find the correct method which i should be using for MaterialTakeoff schedules to get the fields.
The code i’m using:
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import*
schedule = UnwrapElement(IN[0])
definition = schedule.Definition
fieldnames = []
def getFields(schedule):
for id in ids:
param = definition.GetField(id)
fieldnames.append(param.GetName())
OUT = fieldnames
Maybe somebody here has an idea?
