Get fields of a schedule
i wanna get all parameters of a schedule (fields) in python:
#Template
#DraxlA
#19.07.2023
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
#functions
def tolist(x):
    if hasattr(x,'__iter__'): return x
    else: return [x]
#collector
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Schedules)
all_elements = collector.WhereElementIsNotElementType().ToElements()
#filter
schedule = [i for i in all_elements if i.Name == "Türliste WGA_AP"]
#element = UnwrapElement(tolist(IN[0]))
params = []
for i in schedule:
	params.append(i.field.GetName())
OUT = params
2023-07-31_11h16_55
my code has no error but remains empty! there should be 63 Parameters.
KR
Andreas
You have a ViewSchedule object in the error.
You want to get the list of fields; note that there isn’t a ‘Field’ property for view schedules, so you have to go on a bit of a hunt for that data.
There is a “Definition” property, the output of which is a [ScheduleDefinition] (ScheduleDefinition Class) object.
The ScheduleDefinition object has a method to GetFieldOrder(). The outputs of which are a list of ScheduleFieldId objects, which you can likely use to get the assocaited ScheduleField object.
The ScheduleField class has a ColumnHeading which I think will return the heading as it would print which may be enough. You can also get the ParameterId if it has one (count, formula, and percentage fields wouldn’t return an id so you’d get Null), which can be used to get the parameter and eventually the name as well.
Not a quick exercise, but it should provide some degree of clarity on how Schedules and Parameters (if you go that deep) are configured in the Revit file.
In line with using ScheduleDefinition as @jacob.small directs. You can use the definition to get the field count and a schedulefield list. Range out the count and use schedulefield getname to list out all the names of the schedulefield list. May not be the most proper way of doing it, but the code below works.
sched = UnwrapElement(IN[0])
fldnames=[]
fld=[]
schdef = sched.Definition
fldcnt = ScheduleDefinition.GetFieldCount(schdef)
int = range(fldcnt)
for i in int:
	fld.append(ScheduleDefinition.GetField(schdef,i))
for e in fld:
	fldnames.append(ScheduleField.GetName(e))
OUT = fldnames
