Hello all!
I need help with solving the python issue in dynamo!!
I want to change the function data on material like from Finish1 to Finshi2 using python script. But I failed!!! Please help me so that I can solve it.
I attached two pictures here as references.
Thank you so much!!
The problem is that you’re giving the method a string instead of a materialfunctionassignment enumeration item.
See the link to the revit API docs website below for the possible inputs.
https://www.revitapidocs.com/2020/1cbeb006-f7a2-f6d2-491f-faa0b9a006fc.htm
Use this code to get the materialFunctionAssignment value depending on the string you’re using as input.
import System
clr.AddReference("RevitAPI")
input = IN[0]
OUT = list()
x = System.Enum.GetValues(MaterialFunctionAssignment)
for i in x:
if i.ToString() == input:
OUT.append(i)
Also for future posts, it would be helpful to post a direct link to the page of the Revit API docs website you’ve been using along side with the picture
