Hi. So, I got 3 lists. 2 of them are corresponding to revit elements. (I filtered them through a value in the comments section), and the third are the values I want them to replace. The first 2 are to correspond the elements to the right value I want to replace. Maybe with an image will be easier.
The first is the list of the elements (1 to 10) and the second both lists from excel which have the “ID” (1 to 10) and the value I want to replace. Thanks
yes. In this case a diameter. I exported from excel a list like this
Pipe Diameter
1 20
2 20
3 20
(for example)
And I associated each element to a number on the comments section, so pipe “1” has 20 mm diameter. I already have the lists, but I can’t make the connection from the pipes to the corresponding element. So, Element 1 should corespond to “1” and so on. (The values are already organized, I just need to pick point them) (sorry for being so explicit but I think is the best way to be clear)
In your original export, I would suggest exporting the elements ID’s - so that during your import you can associate each piece of data with the element.
Export: Log Element.ID to your list
Import: Use Element.ByID (clockwork) to re-associate those elements as intended.
So, as far as I understand your question, you need the ‘true’ values from the first image to join with the pipe diameter from the second image lists.
You can use this node.
I am sorry if it does not help you. I did not quite get your question right. Please feel free to like if it helps you.
