My security settings at work don’t let me download and install packages thru the Dynamo Package Manger. How do I manually install them?
Use this site:
https://dynamopackages.com/
Hi, when I download them, Dynamo wont install them?
I.e. when i move them into the roaming folder and unblock .DLL the nodes still dont appear in Dynamo
Hello Josh,
A few questions / points:
- Are you using Sandbox or a Host (i.e Revit, Civil 3d etc.)? There are a few different places to copy through into depending on your situation!
- You also have to copy it through into the correct version; if you have Dynamo 2.0.3 in Revit and Dynamo 2.3 in Sandbox - then it should be in both applicable locations.
- If you try to open a package that contains Revit nodes inside of Sandbox - it may not show up.
- You may also be running into this problem: https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-transport-layer-security-updates-require-revit-security-fix.html - if so, please update your Revit version to the latest patch
i had the same problem, i could’t connect in dynamo for revit.
i downloaded dynamo sandbox, the i get the package in that platform. manage packages copy the floders. ande paste it in manage packages from revit
Does anyone has solved this problem, I also seem to be facing the same problem here, not able to install packages through the install package tab.
solution for anyone having this trouble, dynamo for Revit here : https://www.youtube.com/watch?v=TEmbIKvreVk&list=PLJTzOW8s-wuZ_LVjkJeugOKX4XS1qubVx&index=5
