I installed Mantis Shrimp for Dynamo and Grasshopper. But the Components in Grasshopper are not working. It Say the Following error.
When I try to use any component in gh It says:
- Solution exception:No module named mantisshrimp
Even though the rh_Path.txt is in the Right Location, the Error above is still showing.
Any Idea why?
This is the Message coming in the Script editor
Runtime error (IOException): Could not add reference to assembly ProtoGeometry
Traceback:
line 11, in , “C:\Users\Oliver\AppData\Roaming\Dynamo\Dynamo Revit\2.0\packages\Archi-lab_MantisShrimp\extra\mantisshrimp.py”
line 22, in script
What version of Dynamo do you have installed?
Ps. I can’t get Rhino 6 to work on my machine just yet. I won’t be able to debug the issue here until I get that resolved. Apologies.
Hi Konrad,
I am Using Dynamo 2.0.
I am having the same problem can you help me?
Hi Konrad, hi all
Same problem or almost - from one hand RH v6 MantisShrimp seems to work, but when I close and re-open RH+GH Mantis seems to lose the correct path stored in the rhPath.txt
on the other hand, Dynamo v 1.3.4 seems not to work properly I can’t export simple NURBS surface ( I have also noticed that nothing happens when I try to write RhinoCommon.dll path from Dynamo and consecutively to write any GH file from it).
