I have makro code written by a previous employee
* Created by SharpDevelop.
* User: xxx
* Date: 2020-01-15
* Time: 14:29
* To change this template use Tools | Options | Coding | Edit Standard Headers.
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
namespace ElevationParameterENU
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
[Autodesk.Revit.DB.Macros.AddInId("35453963-A3B1-4F75-9656-3149B8DA9BD0")]
public partial class ThisDocument
private void Module_Startup(object sender, EventArgs e)
private void Module_Shutdown(object sender, EventArgs e)
#region Revit Macros generated code
private void InternalStartup()
this.Startup += new System.EventHandler(Module_Startup);
this.Shutdown += new System.EventHandler(Module_Shutdown);
#endregion
public void OpeningTag()
//UIDocument uidoc = ActiveUIDocument;
Document doc = this.Application.ActiveUIDocument.Document;
// 1. All Generic Instances
ElementCategoryFilter filter = new ElementCategoryFilter(BuiltInCategory.OST_GenericModel);
IList<Element> instanceList = new FilteredElementCollector(doc).WherePasses(filter).WhereElementIsNotElementType().ToElements();
// To select and count instances at completion
IList<ElementId> toSelect = new List<ElementId>();
long count = 0;
// 2. Conditioned Instances
foreach (Element ins in instanceList)
double elevation = 0;
IList<bool> flag = new List<bool>();
bool heightIsAvailable = false;
bool BasedLevelIsAvailable = false;
ParameterSet paramSet = ins.Parameters;
foreach (Parameter param in paramSet)
if (param.Definition.Name.Equals("Elevation"))
elevation = param.AsDouble();
// The separation of the two loops is necessary to avoid confusion in taking parameter value
if (heightIsAvailable = BasedLevelIsAvailable = true && param.Definition.Name.Equals("Oś otworu")) // "Oś otworu" - custom instance parameter"
using (Transaction t = new Transaction(doc, "Set parameters value"))
t.Start();
param.Set(elevation);
t.Commit();
count += 1;
flag.Add(true);
if (flag.Contains(true))
toSelect.Add(ins.Id);
// 4. Report
if (toSelect.Count > 0)
TaskDialog.Show("Wykonano na " + count + " otworach", "Zakończono: Rzędna - oś otworu - otwór okrągły oraz otwór prostokątny");
else
TaskDialog.Show("Revit", "Nie znaleziono obiektów");
UIDocument uidoc = new UIDocument(doc);
uidoc.Selection.SetElementIds(toSelect);
the code worked in version 2018.3, but in 2022.1 it does not complete the values properly (enters 0.00 in each point):
Should be:
It is:
Have any of you encountered this problem and have a solution? I’m asking here because I don’t work in C# however I need to fix this ![]()
