Hello everyone,
good day today indeed :)…
I want to convert rooms into the mass category using node Direct Shape and there is just one small thing. On one room I am getting that the material is not asign to it and this room I can’t override it with view filter. Is somebody knows what could be a problem?
Thank you in advnce for your reply and wish you all good day.
Damir
Was checking other possibility and made just one material with basic settings and multipled it with a list to applied on total of all rooms and that gave me result which I wanted. Here is a script if someone needs it. I wish you all nice day :).
Maybe a little late but regardless;
- It would have helped if you had pinned your preview bubbles so we could see what was going on.
- Setting
Lacing to Longest instead of duplicating your material x times may also have ‘done the trick’.
Thank you @bvs1982 for your reply :)…Will try that one too..
