Making lins from excel information, but in an angle
Hi, I work on a farming company and I’m using Dynamo to make plant rows from an excel filled by the client,
The Issue is that the routine only works when the main side is a straight curve (or 90° angle), but sometimes it´s on a angle or a round curve. I need a way to maybe select a starting line or some solution like that. (I’m really new to Dynamo).
I´ll post the routine I’m using right now.
Hello @SergioPC and welcome :wink: im not really sure, could you share your excel and graph then we can take a look :wink: but no guarantee as I have to admit I don’t do that much farming :wink: :wink:
Yes of course, thanks for the reply. I trimed the excel as much as posible so it only shows the lenght of the rows and the separation between them, which are the only two parameters I take from Dynamo [EDIT: The forum didn’t let me upload the excel file since Im a new user]. Also in the pictures you can see an example of a great and easy field and a complicated shaped field.
My problem is that in my routine I can only set a straight line as my starting point because I don’t know how to give it an angle (since my knowlege on dynamo is limited). This is not a problem with fields like the “great field” example. But wen I recive projects like the “Problematic field” then mi routine doesn’t work since the shaoe that I get as a result its no even near to the shape of the field.
I uploaded an image of the result of the running routine. Its looks something like this. You can see that It creates a shape that should be exacly like the shape of any field I input
not sure…doesnt it depends on your data from excel ? i guees we will need them…but there are many ways we can create curve array it depends on the shape and the data as well…here is an exemple there follow a curve, but not sure at all…
Revit_9VpmMtOa5n
or something ?
Actually the first video its pretty much what Im looking for. Could you upload the image of that routine please? :raised_hands:
