LoopWhile for a variable X, need output for a variable Y
Hi all,
My script in attachment is a principle where I want to loop the value of X of an analytical node, calculate the reaction force for it, and return the value for the FZ reaction force. I.e. return all FZ values for a range of X between 2 and 8 meter, each 1 meter increment. This can’t be solved with ranges, because each translation of X needs the RSA.Calculate node to start simulations in Robot Structural Analysis to return a result. So I started an initial situation with nodes and a bar. One of the nodes gets transferred to a custom node, which handles the translation of the node within RSA and which launches the calculation and returns the result of FZ.
When I connect FZ to the LoopBody of the LoopWhile node, then only one loop is done. When I connect X then it loops until the “upper limit”, but still I can’t return the value of FZ.
Anyone that can help me figuring this out?
Thanks ! Dieter
Loopwhile 2
General Project: LoopWhile SimpleBar
Custom Node: BarAnalysis
Hi Dieter,
You must treat each output on your custom node as a separate function for this to work. Unfortunately the default "LoopWhile "node can not accept more than 1 function. Therefore we will have to build our own loop:
2015-03-27_112711
However I’m not entirely sure if this method will work well with custom external libraries like RSA. I can’t test your workflow because I don’t have Robot unfortunately.
Hi Dimitar,
Perfect, it worked ! Thanks a lot !
Dieter
LoopWhile w Design script
looptest
temp3
Technically, it should work for your case as is.
