Hello!
Could someone explain me why the node Room.ByLocation is only creating one room instead of 6 at each Point? How can I loop it through all the points?
Hello!
Hello @adkaJK5HX I guess you will need give some name and numbers with unique number. as it seems you have 6 rooms…and probably set lacing to longest
Thank you! Adjusting lacing to longest was the solution.
