rgb.txt (107 Bytes)
i have a txt file with about 1700 + material names and RBG values ( ive attached a small sample)
rgb.txt (107 Bytes)
Haven’t seen the script but have you tried turning it into a custom node and then plugging the list into it afterwards? Custom nodes tend to do repeated things that normally only work for 1 item.
clr.AddReference
clr.AddReference
def ToRevitColor(dynamoColor):return Color(dynamoColor.Red, dynamoColor.Green, dynamoColor.Blue)
def ToDynamoObject(revitObject, isRevitOwned=False):return revitObject.ToDSType(isRevitOwned)
newMaterials = []
mat_name = IN[0]
color = IN[1]
transparency = IN[2]
for i in mat_name:
new_mat_id = Material.Create(doc, mat_name)
new_mat = doc.GetElement(new_mat_id)
new_mat.Color = ToRevitColor(color)
new_mat.SurfacePatternColor = ToRevitColor(color)
new_mat.CutPatternColor = ToRevitColor(color)
new_mat.Transparency = transparency
newMaterials.append(ToDynamoObject(new_mat))
OUT = newMaterials
Tip for taking pictures of graphs, if you zoom in until you can fully read a single node, then click the camera button, it will take a picture of the entire graph at that zoom level, you don’t need to worry about zooming out to see everything.
Your inputs for the ARGB node should be numbers [int] not strings
You can use the zip function in the python code.
clr.AddReference('RevitAPI')
newMaterials = []
mat_name = IN[0]
color = IN[1]
for i,y in zip (mat_name, color):
new_mat_id = Material.Create(doc, i)
new_mat.SurfacePatternColor = ToRevitColor(y)
new_mat.CutPatternColor = ToRevitColor(y)
new_mat.Color = ToRevitColor(y)
OUT = newMaterials
Create RGB Materials2.dyn (15.8 KB)
Hi Alban,
Very interesting
if you wouldn’t mind humouring me…
Say we wanted to make 3 black materials, 2 red, 4 orange… is it possible to do a version of the zip which has 2 different length lists? Perhaps with a range? Or do we always need to match the number of colours to the number of names?
Thanks,
Mark
When using the zip() function, you need lists of equal lengths, like when you use list.transpose
First, you can thank for the help already provided.
Second, you can look at yourself in the API.
Third, you can create an appareance asset from an existing rendering asset, duplicate an asset, and set it to a material.
AppearanceAssetElement Class
Yea i looked at the API. but is there a way to access the Image (Texture) of the appearance asset. I Created Jpeg of those textures in Python itself using the PIL library so maybe i can assign the texture directly?.
Hmm… I just saw this video, it seesm to be possible But it would only work with Revit 2018.1. i have to Update Revit and Try tomorrow.
