Does anybody know how to do loop for evry items in list ? Because now my script take first item “Cell” and only this one is true, but the second one is false but in my opinion should be also true.
You will need to change the lacing.
https://primer.dynamobim.org/06_Designing-with-Lists/6-1_whats-a-list.html
How to do this list as items from objects directly automatic instead of write it manually incase if i have more elements
But here also i write manually “fraise-tagada”
i need to take list item from node (String from objects)
hello you retrieve the name of the node concerned with a + to generate a series
Sincerely
christian.stan
