Looking for someone who has built a parametric Revit/Dynamo system from scratch, not just contributed to one.
We design and fabricate engineered structures and need to bring our configuration and modeling system in-house. The focus is on building a rule-driven framework that controls assemblies, outputs drawings, and generates BOMs in a clean and scalable way.
I’m not looking for general BIM support. This is about system architecture and long-term ownership, not project modeling. This would start as a short-term consulting engagement.
If you’ve done this before, I’d be interested in talking.
I can’t help directly - you’d need to reach out to start a consulting contract if that is what you’re after, but people on my larger team and I have helped quite a few in this space.
I can share that there is a good process to start down this path. Failing to do the initial legwork will eventually lead to some kind of costly rework or even failure.
  • Validate the cost today without the tool
  • Define the user base (internal design team only? External consultants? Customers?) and confirm that you have the infosec in place to deal with such.
  • Confirm your users have the expertise internally to utilize the output of the tool (a Dynamo based tool means you will need internal expertise in both Dynamo and Revit).
  • Confirm you can commit to the operation and maintenance costs of the tool - this should be a literal line item in your annual budget not a thing you address later if it’s a consultant provided tool; or a set chunk of staffing hours if you plan on maintaining it yourself.
  • Define the input and output types clearly and completely. Looking at inputs if one set of the users want to just provide [width, length, height], but another set wants to also include [location, orientation] and another wants to use a 3D geometry you actually need three separate graphs. When you add in outputs if one set of users want just a Revit model and another wants Revit model and excel and another want Revit, excel, and DWG then you now need 9 tools (3 input tools * 3 output tools). The only alternative is to ensure all users are able to build/modify the tools on their own.
Hi Cihan,
Here at https://www.reope.com/ we work with a variety of firms building custom digital tools that automate their workflow. This includes rule driven element placement, drawing production and schedule creation.
We are experts at creating custom Addins for Revit, as well as the digital and data infrastructure which supports. Custom Software Development - Reope
We are also a lot of fun to work with!
If you feel we’re a good fit, feel free to drop us a message :slight_smile:
Thanks,
Mark
DM me please
