<div>We want to follow up on our recent survey entitled “Integration Between Revit and Dynamo Survey” and thank you for all the great feedback. Most of the requirements and feedback are quite clear, but there are four aspects we hope to have follow-up discussion to confirm the requirements on this forum:</div>
<div>
· Document management
In response of question “What tasks do you perform with your visual modeling tools?”, some of you answered with Revit project management or housekeeping work. We are very curious on specific use cases in this area. Could you provide more information, or let us connect with you and have a chat?
· Fabrication
In response of question “Is there an important task that you want to accomplish by using visual programming that is not well supported by your visual programming tool?”, some of you mentioned fabrication process and some detail workflows such as part labeling and part isolation. We hope to get more complete fabrication application workflow and use cases to clarify the detailed requirement. Could you provide more information, or let us connect with you and have a chat?
· Design optimization from algorithms and analysis
Some of the algorithms such as “Galapagos” and analysis tools have been integrated with Dynamo according to the survey feedback. We would like to collect more specific and detailed description to identify the workflow and requirement.
· Annotation and documentation of structural system
Some of you mentioned that it’s pretty difficult to document structural systems created in Rhino, and Dynamo might help a lot in this regards. We would like to learn more clear workflows such as “does the annotation and documentation is used by the architects to deliver model information to structural engineer?” to clarify the requirement. Could you provide more information, or let us connect with you and have a chat?
</div>
<div></div>
