Hi all,
I’m a bit stumped on this one, I’m trying to use a logical if to pass some lists into Revit but for some reason the list is not going through? Looking at Dynamo Primer If should be able to pass lists with no issue.
Hi all,
it needs true input as well.
Yep, that did it. Thank you.
As @rajeshjamariya16 said, put something into true.
If the test is true, what do you want the node to output?
If you want a blank string you need to feed a blank string into the “True”
EDIT… Ah you’ve got it
