I’m having trouble using an excel file to take the name of shared parameters in it, with their settings; and load it into the project. I’m using some Python 3 code here:
clr.AddReference('RevitAPI')
# Function to add shared parameters
def add_shared_parameters(param_data, shared_params):
app = doc.Application
shared_params_file = app.OpenSharedParameterFile()
if shared_params_file is None:
raise Exception("Shared parameters file not found.")
for i, param in enumerate(param_data):
try:
param_group = param{0]
param_type = param[1]
param_group = param[2]
bip_name = param[3]
is_instance = param[4]
param_name = param[5]
# Find the shared parameter in the shared parameters file
for group in shared_params_file.Groups:
if group.Name == param_group:
for definition in group.Definitions:
if definition.Name == param_name:
# Create the shared parameter
new_param = doc.FamilyManager.AddParameter(definition, BuiltInParameterGroup.PG_DATA, is_instance)
break
except IndexError:
print(f"IndexError: Check the data at index {i} in param_data or shared_params.")
# Example usage
param_data = IN[5] # Connect the Excel data to this input
shared_params = IN[6] # Connect the filtered shared parameters to this input
# Ensure that the length of param_data and shared_params are consistent
if len(param_data) != len(shared_params):
raise Exception("The length of param_data and shared_params must be the same.")
And the sample excel list is formatted as so:
| Column 1 | Column 2 | Column 3 | Column 4 | E | F |
| Shared Parameter Name | Shared Parameter Group | Parameter Type | Parameter Group | BIP Name | Instance |
