Do you think it’s possible to ask Dynamo to check revit version upades of linked filesI>The aim of my question is to know if revit files haves been created in revit 2021.1.2 or revit 2021.8 or 2021.1.10 for exmpale.
Thanks!
Gaëtan
Thanks!
Gaëtan
Hello @Gaetan_DENIS and welcome to the forum ;)…try document properties from Genius Loci
guees i misunderstand you are after the build from link, try this one here and just feed in the link instances
import System
clr.AddReference('RevitAPI')
from Autodesk.Revit.ApplicationServices import LanguageType
from Autodesk.Revit.DB import Document
# Function to get enum name
def enumGetName(enum, enumClass):
return System.Enum.GetName(enumClass, enum)
# Current UI application
app = uiapp.Application
# Function to get Revit version info
def get_revit_version(doc):
if int(app.VersionNumber) > 2017:
fullVersion = app.SubVersionNumber
fullVersion = str(app.VersionNumber)
versionName = app.VersionName
versionBuild = app.VersionBuild
language = enumGetName(app.Language, LanguageType)
versionShort = int(app.VersionNumber)
return versionName, versionShort, fullVersion, versionBuild, language
# Get active document
# Get link document if provided
linkDoc = IN[0] if isinstance(IN[0], Document) else None
# Output results
OUT = get_revit_version(linkDoc) if linkDoc else get_revit_version(doc)
Well i didn’t expect a response as fast as yours! Thanks I will have a look. By the way Model checker can do it but very interesting with dynamo thanks!
GAëtan
yeah try it…and cheers to @GavinNicholls for the original script, but without option for link
