just curious is it possible to loop if the input list is unknown depth:
e.g.
this is with fourth depth, but I want a function to work on various depth i.e. fifth, sixth…
is it possible?
e.g.
is it possible?
Hi @newshunhk
in my opinion, the easiest way is to build a recursive function like below. Remember that by calling the function again the function run before hasn’t stopped running. It means It takes a lot of memory and if you have a big dataset you can run out of memory. Alternatively, a while loop could be used instead.
import sys
input_list = IN[0]
output_list = []
def iter_func(input_list):
if any(isinstance(item, list) for item in input_list):
for item in input_list:
if isinstance(item, list):
iter_func(item)
output_list.append(item)
if len(input_list) > 0:
for item in input_list: output_list.append(item)
OUT = output_list
it works perfectly! thank you!
