Cant get this to work, HELP!!!
OutPutList=[]
for x in IN[0]:
Looplist = []
for x in IN[0]:
if x==1:Looplist.append(0)
elif x==2:Looplist.append(3)
else:Looplist="1"
OutPutList.append(Looplist)
OUT=OutPutList
OutPutList=[]
for x in IN[0]:
Looplist = []
for x in IN[0]:
if x==1:Looplist="0"
elif x==2:Looplist="00"
else:Looplist="1"
OUT=OutPutList
Hello
Good reading
Python script:
# The vital minimum to do various things
import sys
OutputList=[] #Your container
for x in IN[0]: #Your loop
if x==1: #A removal for the loop
OutputList.append(0) #Assignment (addition) to the empty container (outputlist)
elif x==2:
OutputList.append(3)
OutputList.append("1")
OUT = OutputList,type(OutputList[3]) #Assignment of the container (filled) at the end of the loop at the exit (OUT)
cordially
christian.stan
@BIM_Mrbrango it depends on what you are looking for ⦠is this it?
import sys
OutPutList = []
for x in IN[0]:
if x == 1:
OutPutList.append("0")
elif x == 2:
OutPutList.append("3")
OutPutList.append("1")
OUT = OutPutList
Hi and Thanks to the both of you.
Iām getting the length of āENDā of filename, if its 1 digit then add 2(0) and if its 2 digits then add 1(0)
I tried your code but the sam problem
Itās still a little unclear what youāre after. Are you trying to normalize the string length by padding with 0? You can use a node for that or you can write a simple If statement (in a codeblock or python):
Here is modified (as you have 3 possibilities (2 from M. Nick))
import sys
if len(x)==1: #A removal for the loop
OutputList.append(x+"00") #Assignment (addition) to the empty container (outputlist)
elif len(x)==2:
OutputList.append(x+"0")
OutputList.append(x)
OUT = OutputList #Assignment of the container (filled) at the end of the loop at the exit (OUT)
cordially
christian.stan
Hi Nick_Boyts
I will try to explain, I have families that I want to rename and picture below is my goal.
The red line is a fixed carachters depending on the family, the blue is the sequence depending on the numer of families.
And in in that category there are 5.
So the serie will be something like this:
QA101,QA102,QA103,QA104,QA105
But if a category contains more than 9 familes I want it to look like this
QA110,QA111
That just seems like counting the number of families in a category and adding it to 100. You can do that with a sequence based on total count or step through each family and keep track of a counter. The former is much easier but the latter could be seen as the streamlined version if you already have a list of categories and their families.
You are absolutly correct, but the sequence is not keeping the formating to number 9, Iād like to have
number 01,02,03 and so on to 10?
I succeeded in a way (Padright)
y=x+"00"
OutputList.append(y[:3])
cordially
Christian.stan
Is it formatted as category (QA) and count (1xx) or as category (QA1) and count (xx)? If youāre starting the count at 100 then thereās no formatting. If youāre starting at 00 (and the 1 is part of the category) then you just pad the left like Iāve shown with 2 digits. Create a sequence of digits based on family count, convert to string, then pad.
Thanks Nick_Boyts!
You are absolutly correctā¦
