I would like to pass a list created in a new parameter generated on revit, which node do you recommend?
thank you
What does the error message say?
Have you tried converting the parameter value to a string before passing it to the SetParameter node?
Have you made sure that the parameter you are setting is editable in the project?
@erfajo Yes null values…
@martin.scholl in string? Node name?
this is the file, in short I created a single list that includes Revit both Area and Volume in certain indexes, how could I add this list to the new parameter created in revit?Test 3.dyn (23.5 KB)
ok I’m sorry maybe I was not very clear … the result I wanted to reach theoretically I have already achieved … I would like to know only if there is a way to transcribe the list obtained in a new field of abacus revit previously reported
I probably do not even have to use the node Element.SetParameterByName… indeed surely
