List.Sort by Value Issue
Hello All,
I have a weird situation with List.SortIndexByValue. If you take a look at the image below, you can see that lowest value has index 9 (-8930.xxxxx) but mentioned bloc show that index 10 has the lowest value.
Just to check, I did insert List.MinimumItem and it shows (as it should) that the lowest value is -8930.
Can someone help me with this one? Is there a similar block which works as it should? Can I use something similar?
Thanks in advance for your help.
List seems correct to me.
You lowest value, in the Point.X list, is at pos 9 therefor it is on top
on your List.SortIndexByValue list (at pos 0).
Then 10 at 1, 11 at 2 etc.
But the position 0 as per List.SortIndex is value -4118 not -8930 (pls see image below). That is what confuse me.
Can you enable the preview after rounding please?
My guess is that this may have to do with unit precision - there are a LOT of digits in there.
Yes, sorry, I should do that at first place…
Do they sort correctly if you skip these nodes and directly feed point.X into the sort by key node?
FYI @Michael_Kirschner2
Yes, it seems to be just like it should be. Thanks a lot for your help. I thought that I need to use sort of value to feed sort of key…
Thanks again for quickly responding.
False alarm: this is working correctly.
The results of the node don’t read as most nodes though.
Read the results as:
The 0 index comes from index 9.
The 1 index comes from index 10.
The 2 index comes from index 11…
The 10 index comes from index 0.
The 11 index comes from index 8.
The 12 index comes from index 4.
Not: the lowest value is from index 9…
That is what i said :smile:
@jacob.small
@bvs1982
Thanks, I did not know that. :frowning:
Now, it seem that I needed to use List.Sort instead of SortIndex.Value…
