Cant see whats wrong, help!
Why is it not sorting correctly by list.indexof
Seems a bit difficult to understand. Could you explain in a simple manner with expectations?
Hi @_Vijay
At node GetItemAtIndex you can see that I have values of:
13
13
13+13
and so on
I need to seperate every number with a ±sign and sum the value to 26, but when I try to sort list 26 dont get placed at the same index as the original list. How can I maintain structure in List.SortByKey?
You can use python to evaluate the string - use Python from String node with the following line of code
"OUT = [eval(item) for item in IN[0]]";
Hi @Mike.Buttery
Thanks for your example, but the example ends up with the same problem I try to solve
The order after spliting + och Sort by Key dont match the original list.
Any solution?
Perhaps sorting by key is not what you want? Or after the string split use item[0] in a code node which will only take the first number
Hi Mike,
Thanks for your effort, I did another solution that works
